oliver super 88 wont start
Anonymous-0
i was in the field when i ran out of gas i went to fill him up again and he wouldnt start i thoght running out fuel might oe sent alot dirt to carbuerator so i had rebuilt but same old story turns over real fine but wont start any body?
Disconnect fuel line at the carb., should have a good steady stream of gas. If not, sediment bowl or filter may be plugged. I assume you put enough gas in it to fill tank beyond the fuel outlet.
Paul
Fill in the blanks. DO you have a good flow of gas to the carb?????? Do you have a good blue/white spark that will jump a 1/4 inch gap?????? You need to be able to answer yes to both or it will not run
