Ed S.
- Location
- Middle Tennessee
Tonight, I pulled the second rear wheel center out of the e-tank, and got it prepped and ready for wire-wheeling prior to primer.
Finished putting primer on the underside of the lift assembly, and also attempted to build up the lift follow cam by brazing it (it was worn down a bit), but couldn't get the heavy cast iron hot enough for the rod to stick. It'll just have to be worn.
Finished up by tinting the grey paint I had bought a couple years ago to match the original 1950 grey color, and got reasonably close to it. However, didn't have as much luck with the red paint - it turned out more tomato red than what I wanted. I may bite the bullet and order another gallon from a source which claims to exactly match the original red.
My tinted grey color is inbetween the two reds in the photo - hard to tell from the pic, but once it dries, it should be pretty close to a part I used for comparison which still had some original grey on it. The rest of the hood is the grey as it came from the factory ("Ford Grey").
es
es
