Options for building a Case pulling engine - 466 ci limit
SlopBucket
My cousin has an unfinished Case tractor that we would like to complete and pull in the Hot Farm class with the TTTPA (Texas). He's already got a bare 451 block and 2394/2594 heads, but we're open to other suggestions. My Question: what would YOU put together if working under the following restrictions? 466 ci displacement (we think they'll allow up to 471 ci), water injection, Bosch P pump with 13mm plungers, Garrett GT42 turbo, and a 4000 RPM limit. We've been told that we might be able to use Cummins 8.3L pistons and liners. Your suggestions and insight will be appreciated! Jerrad Voth
The problem with the 8.3 stuff is you would be 475 cubes with stock stroke. The next problem you face is if you left it stock bore the heads he has wont work. The valves are wider than the 4 3/8s bore. Most guys i know have just left them a 451 and have done good head and cam work to them. My opinion is leave it 451 and save the money of boreing it put that in heads. Then put some valves that are a tad larger, smaller stem size and port work. Then have a good cam ground you have to get air in it to burn lots of fuel. 15 cubes isnt going to gain you that much anyway.
Thad,
Thanks for taking the time to reply. Correct me if I am wrong, but don't the 451 heads have power cells (Lanova style) that aren't turbo friendly? If there's a trick to making those heads work would you mind filling in some of the blanks? Is there another head that we should look for? This may lead into some discussion about a proper fuel system. Your reply was exactly what I was hoping for. JV
Case made 2 451s the early one was a powercell engine in a 1030. The other is a direct injection style from say a 1070 thru 1270. Thats the type you would want to use. So basicly you want to start with a 70s series engine. Heres another way to look at the cubic inch diff. Say you will get a HP for every .50 of a cube. Thats 466 Divided by .50 = 932 hp. 451 by .50 = 902. Lets say the extra money spent on heads gets you a hp for every .45 now the 451 is 1002hp. Ive seen way to many built that they worry about getting big fuel #s. Then they cant burn 1/2 of what the fuel system will do because they cant get enough air. Thad
Thad, a friend had a 970 with a 504 with oversize valves and he flycut the sleeves to allow for valve opening. As long as a portion of the firedam remains intact it's not a problem. They were also cutting the stock fire ring out of the gasket and useing a stainless firering as they were boosting about 75 lbs off the line and stock gaskets were not cutting it. OEM sleeves were cracking so Darton became the sleeve of choice also. mEl
