Ordering engine bearing sets
dljohnson
I have now got my Continental Z134 completely disassembled. The crank is removed. I found out what that horrible knocking was; my third cylinder rod bearing was trashed. I know I need to have my crankshaft turned and ground down. My question is then how will I know what bearing sets to order; std, .01 .02 or.03??? Do I need to measure the diameter of the rod and main shaft before they grind it down? What should it measure as it came from the factory?
the machine shop will do all that.they will need the original crank journal measurement.they will tell you how many thou. will have to come off.
