Neighbor has one that ate the pump about 3 months ago. Quit about 2 days ago, no pump noise. 116K miles, 4wd, auto, 4.0L six. No codes. Pump in tank. This one has NO fuel filter, has mesh plastic on intake of pump, also NO "pressure regulator" on/near the fuel rail. On top of the fuel pump assembly there is what "appears" to be a pressure regulator of some type. When holding pressure against the input side(of the regulator) there is very little output. I am taking this to mean that it"s plugged or restricted internally, did I mention you can"t separate this off of the pump assembly housing? Anyone come across this marvel of engineering? Any testing to do? Thanks in advance for any help!
