OT. 98 Cavalier wont start
Anonymous-0
I bought a newer car and let it set for about 1 1/2 month and now it will kinda idle for a few seconds but dies as soon as I touch gas pedal and will die regardless after about 10 seconds. Checked the plugs and they aren't getting wet. Poured a little gas in the intake hose and it started till it was gone. I checked fuel filter and it was fine haven't checked pressure yet but it had pretty good pressure built up when I unhooked the filter. So I do believe its a fuel problem but what should I check next? Maybe the pressure regulator?
Thanks for all your help
Just because it had pretty good pressure when you unhooked the filter dosen't mean that it's enough to make it run. My 1993 Olds.Cutlass Ciera with a 3.3 3300 V6 was having spells were it would die ever so often . Kept getting worse, so my mechanic hooked up a fuel pressure guage and it read like 49 pounds but the book said that it had to have 50-80 per say. Put in a new fuel pump , cured the dieing problem . It hasn't done it anymore after that. You'd be suprised what a few pounds of fuel pressure can do to those computer controlled cars . My mechanic thought that it still had enough pressure to run , even though it was 1 pound below the minimum requirement at 49 pounds . This was on a 93 model so I can image how it would effect todays newer models
Whizkidkyus
Install a fuel pressure gauge to what your pressure is. I did that on a Chevy Citation and found the pickup sock on the fuel pump was covered with rust and dirt when I pull the gas tank. I cleaned the tank and installed a new pump. That fixed the stalling problem. Hal
