OT: Dial before you dig
Lanse
from an email....
Supposidly this is what happens when you hit a high pressure gas line with a post hole digger. He musta been digging a pretty deep hole.
Dialing before you dig is a very good idea. Just hope they give you the right info. The college where I work was doing some expansion construction and the city gave them the wrong location on a water line.
Backhoe broke a 12 in. water pipe and the basement and 1st floor flooded. All our electrical eqmt. is in the basement. Fast thinking maintenance foreman pulled all the breakers before it got really nasty.
At least part of one of the big Canadian lines for PGE goes through the outskirts of my home town, about a 1/2 mi from my parents home. Long story, but a failure of an ex-boss of mine was building a log home up there, hired a contractor to "do some work." It remains to this day, clouded in details, but the contractor uh, scratched? the pipe with a hoe. I knew one of the guys who worked with PGE and asked, "how would you repair that?" at that time thinking BIG pipe, LOTS of gas.
He floored me, says, "well depends on the damage. They MIGHT drop the pressure in the line which will ALLOW IT TO SHRINK!!!!! put a collar around it and then boost the pressure."
I asked him just how damn much pressure is IN there, anyhow?
"About 900"
I remember when that one happened, last September in Appomattox Co., VA.
They're great photos of what can happen when a line does blow. In this case, though, nobody actual dug and hit the line to make it blow. There was a leak that may have been the result of some construction at a nearby pumping station on the pipeline, either from a fracture or puncture to the line. It was just the combination of enough gas and enough air and some cause for ignition to set it off, as there was no one there digging. The only injuries were fairly minor and those folks were at some distance from the rupture in the pipe.
I'd have to google some more to see if they ever figured out what actually set it off, but it's pretty impressive all the same.
In front of my parent's home is a 22 inch main with about 1100psi.
They tapped it for my parents with a lance and C4 explosive (watched em do it)
the lance had a collar about 3" up from the tip. They blew the collar toward the pipe lancing a hole in it at the same time. Then calmly stick welded the flange to the pipe. Serious. JimN
The must have been one hell of a pipe. Lotsa pressure on that one if it is real. About 12 years ago I was using a trackhoe digging out a creek. Everything was marked. I guess they was off and I scratched the side of a pipe with one of the teeth and it shot gas right into the cab of the trackhoe. I was smoking a cigarette and am lucky I wasnt blown up. Here is the real story.
here
OMG!! That is horrible, but luckily no loss of life (according to one of the responders, and I hope he is correct).
We have so much burried stuff now, it is dangerous to do normal farming. Part of the problem is the line burial is often done by a subcontractor so the utility company has no liability, and the subcontractor goes out of business often and re-emerges with a different company name, shedding their liability.
120 and 240 volt lines are to be burried at least 24" deep, by code. So I was doing some final landscaping at a suburban house about 20 years ago. With a Troy Built 6Hp tiller, I hit the main burried electrical supply line to the house. I was not any deeper than 3". The power company claimed that I had removed over 20" or soil and wanted to charge me with the accident. I was damm lucky to not have been electricuted!!
My son-in-law works for a petroleum pipe line company. There is a great amount of corrosion in the pipelines, even though they do a lot to minimize corrosion. But many of the leaks and accidents are due to internal corrosion and internal pressure often exceeding 1000 psi. And yet these pipelines may go through residential neighborhoods. There is a high pressure pipeline within 20 ft of my brother's basement, going diagonally across his property, and about 4 ft from the corner of his pole barn. They determine a leak by monitering pressure drops at the next pumping station. By the time the pipeline company knows they have a leak, an awful lot of gas has escaped and probably already filled up some or many houses. The pipeline company has the status of a "utility", meaning they have the power of emminent domain and can go anywhere they want to.
I have hit and pulled up telephone lines with a normal 4 bottom plow. A neighbor had a guy running a bobcat cleaning manure from their pole shed. He hit and pulled up a fiber optic cable inside the pole shed, and he was not digging!
Yes, call the locate number (here it is 811, IIRC), but they only locate the main utilities, going only as far as the meter. They do not locate the privately placed underground wires for phone, electric, water or sewer. To locate the privately placed wires, pipes or gas lines, you have to hire a private locate company, and that can cost over $250.
If you are digging, good luck!!
Paul in MN
There does not have to be an ignition source above ground to set it off.
According to my brother, {welds/maintains lines like these} when a high pressure gas pipe is suddenly opened to the atmosphere, the tiny dust particles inside the pipe are carried out with the gas. It is believed the dust in all the turbulence can cause it's own "spark" from static electricity.
So if you break one open, run like a mad man.
Same thing happened close to Carlsbad, NM on the Pecos river in 2000, except unfortunately some people camping nearby were killed. Attached is an article about the explosion and pipe corrosion.
NM Gas Pipe Blast
Makes that 24" water main we had pop a year ago that floated a big chunk of a four lane road down the hill look like not such a big deal.
Dave
I worked for ten years as the manager for our local water system. Got very familiar with the One Call Center. We would spend complete days babysitting a contractor working around our lines because no one really knew where they went sometimes. Luckily no gas lines in our area. Used to say, Dig up a phone line and you got a lot of people ------. Dig up a water main and you got a big mess. Dig up a power line, don't matter you wont know it.
Makes perfect sense to me.
I'd have to go back to see just how big a line that was, but it was a trans-continental line with a boatload of pressure, especially being right behind a booster pump. If it blew out the pipe, it would take next-to-nothing in the way of imagination to envision static generated by the soil separating by the venting generating a spark sufficient to ignite the whole thing. we can only be thankful that Lanse wasn't dragging and AC behind a Dakota when she lit off.
ScottyHOMEy is correct. This was a TRANSCO natural gas line that ruptured due to corrosion in a pipe over 30 years old, then power lines may have sparked the explosion. Happened about 4 miles south of my home around 8AM on a Sunday morning and we could see the fireball rising to about 1200 ft. The 800 PSI gas line was shut down almost immediately but residual gas in lines burned for about an hour or so. Two houses within 100 yds. of rupture burned to the ground and several others had heat and explosion debris damage. No one was seriously injured and definitely no digging involved. Photos have made the rounds with lots of false information.
Blew a big 30 or 36 inch pipe about 15 years ago on Britain highway Lenawee County.Tripped the shutoff valve shut at Crocket highway about 15 miles away.I was about 10 miles away and could hear a rumbling sound plain as day.Light snow on the ground was gone for 1/4 mile away,just steam rising.Rural area melted the vinyl siding on a house a 1/4 mile away. Investigation determined backhoe operator dented pipe and it wore through there.They found 2 more he had dented.
In the 1970's we farmed a farm with a big pipeline through it.Every so many years they pressure test them with water well exceeding operating pressure.Well she blew out on our farm and knocked down 6 foot tall corn for several hundred yards from the pipeline to the ditch.Mark
Even if you call before you dig you still need to be very cautious. They sometimes miss things. We had them miss the telephone cable when we were digging a water line trench at work. They had everything marked but the main line. We cut right through it. They were right there to fix it within ten minutes. Cost Dig Test about $2,500.00 cause they missed it. Sure wouldn't want very many of them kind of mistakes.
I knew a welder who could weld on a live 8" lpg propane gas lines. Not sure what he was doing or why, but as long as he didn't burn through. I think he was welding on or around well heads for underground storage wells. Plus propane is cold anyway.
(quoted from post at 20:00:51 05/29/09) I knew a welder who could weld on a live 8" lpg propane gas lines. Not sure what he was doing or why, but as long as he didn't burn through. I think he was welding on or around well heads for underground storage wells. Plus propane is cold anyway.
So far as I know, all or most all taps are done on live lines. I serviced HVAC here locally for nearly 15 years, and now there's more and more plastic, but where there's metal, they weld taps on "live."
I think most city street service stuff is 120-250 lbs. The line coming past my folks semi-rural home is the main feed for my small hometown. I believe it's up around 500 psi or so. For many years, "they" would not tap individual homes off that main line. This comes from the big big really big Canadian tube I mentioned earlier.
When I went to "gas" school, the local (Spokane) then Washington Water Power, had a section of large plastic, maybe 3"? or so, someone had driven a standard 8' ground rod right through the middle of the thing.
We have had one explosion with no resulting fire and one with fire here in Central MO. in the last two years. No one dug, they said the pipe can vibrate and over time resting up against rocks, wear a hole and kabooooommmmmm!
The last one was about 10 days ago near Rocheport MO.
Gene
When I was working for NRCS 12 years ago we were measure'n water ways for a guy and kept hearing something like quail take'n off. Got to looking around one of his washed out gullies and there was a gas line that the ground has washed out around going down a hill. You could see it move'n where it was bounce'n so much. Don't know how long it had been like that but that was one of the few times I broke a sweat work'n there. This fat boy was high step'n it to the truck.
Dave
You don't have to dig very deep to hit a gas main and in some places could certainly do it with an auger digging post holes. A couple of years ago some fellas digging in preparation to put up a new barn a couple of miles from me at Tharp Lake Rd and US12 hit a main, 22" maybe, right in the middle of a tilled field and when it went off could've fit a barn in that crater. One fella was killed. Shook the houses for miles and miles and miles and they did build the barn over it eventually.
Locating to dig first is always a good idea, and the law in many places, but not the end all because underground utilities still get hit all of the time even after being located.
Mark
