OT: dump trailer
Geo-TH,In
Thinking of making a 2 wheel mechanical dump trailer to haul a ton or more of dirt behind tractor. Would you please post pics of your homemade dump trailer? Not really thinking of going with a hyd dump at this time.
Thanks,
George
50 years ago my father did just that. The bed off a county truck looked like a tri-axle bed, all steel, but it was only a cubic yard and a mechanical dump. Pull a lever, give a jerk and it dumped. Trying to get ideas and I would like to see how others have built theirs.
George
if you're going with an old truck as a dump trailer why not use pto to power the dump, neighbor had one 40 years ago
I have the back half of a old 1 ton graintruck made into a trailer . Has wood sides and floor like a grain truck but works for dirt and firewood . It has a hydraulic hose hooked strait to the hoist to dump . Have not used it in several years but sure was handy , floor is rotted out , I have a 1 ton gravel bed to put on it just aint got around to it .
If you are making one from scratch, you can be creative. Think about a 2 or 3 way dump and go ahead and reinforce for the hydraulic cylinder you'll be putting in later. Some of the older wagons here are 2 way (left and right) with a wheel you turn (gear and shaft) to dump them.
Dave
Here is ta picture of mine I have been working on for two years but haven't finished yet.
If you're brainstorming a dump trailer using that container from the other post, you probably won't be happy with it............
This is a nice simple design that you can be creative with. Just picture it closed (let down) and hinges (2 clevice type) on both sides and back to secure the bed to frame. Remove hinge pins as necessary to dump laft, right, or back. Works real slick.
(quoted from post at 07:01:22 09/23/10) Here is ta picture of mine I have been working on for two years but haven't finished yet.
Here's one on ebay that you can get an idea from the pics. It has 4 hinge points for a 4 ton wagon.
http://cgi.ebay.de/Kipper-3-Seitenk...Landtechnik_Traktoren&hash=item4aa4ed889d
