OT-Favorites
GA Dave
I have a couple of favorites that no longer apply. How do I delete them? Right clicking does nothing. Thanks for any help. David............
On mine you click organize at the top of the folder. Then you choose the favorite and click remove.
Hope this helps.
Dave
I think that is the first time I have ever helped some one with a computer problem on here. Feels kinda strange.
Glad I could help.
Dave
(quoted from post at 21:47:26 09/09/08) I think that is the first time I have ever helped some one with a computer problem on here. Feels kinda strange.
Glad I could help.
Dave
Mine said delete but worked the same as remove. BTW, I opened a account on photobucket but if I post a picture it is very small. Any way to enlarge where I can understand? Thanks again kyplowboy. David..........
You should be able to download a large image on photobucket. Maybe what you are seeing is the thumbnail after you have loaded the image?
If what you have saved and trying to download is a small size then that is what you are going to get in the end unless you put it in a paint program and enlarge it. Trouble is when you enlarge it then you loose the quality of the image as you make it larger. Paint programs dont know where the pixls go so its a random guess where they are added and the color added so it makes it blurry.
Images can be saved in differant formats but jpg appears to be the standard format that most sites accept.
I like images that are at least 350 pixls width and less than 500 pixles width. If you right click over an image and then on the list that opens you click on properties you can see the size and width of the image. Click over the little tractor icon at the top of this page and view the properties and you will see it is gif format and 200 X 57 pxls. You will also see the URL of where that image is stored on the server at YT. That URL is the address you use when you want to link to that image.
If you are taking pictures try and set your camera to take them in a larger size, at least 500 pixls width. A pixl is the colored square dot that goes into making your image.
A gif format has less choices of colors to choose from to make your image. JPG has more colors to choose from. BMP format has even more. More choices of colors mean a better picture but it also takes longer to load. Gif images can use a transparant background unlike other formats.
One other note...Some sites like YT will downsize your image when you downlaod them onto their server. This helps them save server space.
Hope this helps some
Any albums and photos to share with us? Remember they default to public unless you marked them as private.
Super A has you covered with directions. Remember that you can tag portions of the photo in order to describe someone, certain parts, etc. A description of the photo and title can also be given.
Worked with Photobucket myself last evening.
Remember folks one can search the public albums by topic such as UTZ or by poster.
You can change the size of your posted photo within the HTML code copied from Photobucket.
The photo of "Easy" our 46A is displayed with the following code [b:654c4848f0]width="540" height="480" border="2".[/b:654c4848f0]
<a href="http://s200.photobucket.com/albums/aa5/jameslloydhowell/John%20Deere%20Equipment/Memorial%20Day%20Tractors/?action=view&current=IMG_1509.jpg" target="_blank">
IMG_1509.jpg" width="540" height="480" border="2" alt="Photobucket Image Hosting
</a>
To make the photo smaller, change the width and height numbers in proportion.
The photo of "Easy" our 46A is displayed with the following code [b:654c4848f0]width="360" height="300" border="2".[/b:654c4848f0]
IMG_1509.jpg" width="360" height="300" border="2" alt="Photobucket Image Hosting
</a>
Hope this helps.
Posting from Photobucket
