OT Ford truck question
Maxgussam
Hello-
I am considering purchasing a 1999 F-350 with the 7.3L and auto trans. Approx 145k miles.
Aside from the cylinder cavitation issues, which I will check for, are there any other issues to watch for? How durable are these automatics?
Thank you for any advice!
(quoted from post at 15:09:47 09/01/07) Hello-
The auto in this truck is prone to go out and it is not cheap to fix :(
Try this web page to get any and all the info you need for this truck!!!
http://forums.thedieselstop.com/forums/
BUDD
i have this exact truck have 180 thousand on it had a new torque converter put in at 160 they went through the transmission it was not broken but this is the time to go through it had a water pump ,a oil leak on the quick conection on high preasure oil pump repaired rear axal seals most of this was minor exspence did have a bolt back out of the turbo and mess up the fan blades cost about 1000 to have that fixed i use this tk daily my wife used to drive this every day but now lease this to the company i work for pull a 36' gose neck hall tractors for work not every day about once a week get about 17 mpg empty and about 11 with trailer loader use a deablow chip always leave it on toe and haul have always used shell rotela and add fuel additive if i were to buy anouther would have a standard trans know outher people that have the newer tks not so good luck with them all and all i like this one good luck
Thank you for the replies.
I went to the forum, and read of MANY problems with the auto trans.
I think I will pass on this one, and find a manual trans.
If there is one place that has MORE stoopidity than yt.stupid, it IS thedieselstop.stewpid.
Nothing there but a bunch of wannabee truck drivers, high schoolers dreaming of their first 'truck', and worthless a$$holes who have 'chipped' their truck, caused serious and expensive damage, and now are crying because Ford will not fix it under warranty.
