OT: Gravel description?
Gun guru
My son plays little legal baseball and the gravel used on the infield is a real small gravel, (smaller then pea gravel) and is real chalky.
What is this called? The gravel is not round like pea gravel, so it would work well for driveways and roads.
I would like to have 10 or 20 yards for my driveway.
First of all is it brown, or grey, can be made of limeston, or made of washings from sand operation brown rock..Bothe avail here in west tenn for about $6.55 per ton at the source.. Where are you located. Dump it out rake it where you want it and roll it and it just seems to sit up real good....IF you already haf a firm base..
Hello Gun Guru,
One other product you can use is crushed concrete. Use it for a driveway as is. It packs down real well. The more you use it the more it packs. It is used as a base for paving, Its an excellent product.
Guido.
Probably not what they use, but screenings come to mind. They're pretty fine and they set up quite well after getting wet and packed down.
Donovan from Wisconsin
probably crusher fines, there are 2 kinds the plant i work for makes, one is waste fines which is a dirt product used in foundations it will have nothing in it bigger that 1/4 inch, the other is crusher fines, which is ground rock, this stuff is very small, 1/4 down to dust, there is no dirt in it even though it looks like there is,has a variaty of uses probably what is on the field
If it is real fine and has a lot of lime stone powder in it that is what they call dirt base in my area. Back when I drove dump truck in this area we would put down a layer of 2 inch then a load of dirty base to glue it together and then put down a layer of 1 inch clean or if it was on a hill 1 inch dirty which had a lot of powder in it. Also on blacktop jobs we would put down a lot of dirty base and roll /pack it down before the blacktop was laid down
It is called STONE DUST, I know because my church has a ball fild they bought some for. Believe it comes from crushing operations, the leftover dust, rock, dirt particles which pack together well.
Yep I have crushed limestone. But this stuff is more fine and some parts of my driveway have aggregate for the topping over the heavy 1x3 limestone. I have spent $10,000 on gravel since I started building. Capping it off with the stone dust or whatever its called would be nice.
My experience is that gravel products have different names in different parts of the country, and indeed, sometimes you'll find different names from different suppliers in the same area. Your best bet is to take a sample of it to your gravel supplier and tell him what you want.
(reply to post at 07:24:56 07/31/10)
JMHO, another product that works excellent for driveways is RAP (reclaimed asphalt paving)!
Edit: This is asphalt paving that is ground off streets, highways, etc with a big grinding machine and loaded into trucks for disposal or re-distribution. It is about the consistancy of crushed gravel, but packs much better. May or may not be available in your area.
HTH, Dave
Shale is used on some ball diamonds. It's orange colored and is avavailable in different sizes just like gravel. Also used a lot on golf courses. Dave
I put down some RAP several years ago. It was the cheapest paving material available, and you spread it with a blade like gravel, but don't delay. It will eventually set up much like hot asphalt.
