OT: My computer sends and receives data when
is it update information or is it transmitting pvt data what kind of anti virous software do you have
Is it very active or just a little active? The Mac OSX likes to check the navy's atomic clock to make sure it is showing the correct time. Before I replaced the battery my computer was losing track of date and time, but shortly after I turned it on the clock would reset to the proper time because the computer had automatically contacted the navy's clock.
I don't know windows, it could be checking for security updates and such.
Everything from Adobe products to Quickbooks to your antivirus to Realplayer to Musicmatch to Quicktime to Windows itself tries to set itself to update off it's respective "mother ship" out on the Internet these days. This happens whether you're browsing or not.
Also, it could be your PC checking in with the printer/scanner/etc if you have a network printer or another PC on your network. Especially if you have any other protocols other than TCP/IP installed.
Or it could be a pure virus/malware reporting your information back to someone on the web or your PC could have been hacked. This is less likely, but it definitely does happen.
You can open a DOS command box and type in "netstat -a" to see a complete listing of all connections at that instant. It's a little crude looking, but it will show you everything that is going on, in all but the most severe and sophisticated compromises...
Howard
Good advice, HH. I believe "netstat -t" will narrow it down to TCP connections, which is a little more understandable. (At least it does on Linux/UNIX systems.)
If you REALLY want to know what's going over your network connection, you can download wireshark (nee ethereal), which allows you to examine each byte that goes out of or into your machine. Not for the faint of heart.
It's entirely possible that X22's machine has been taken over by a "bot" and is being used to relay spam or other malicious traffic.
Wireshark
Get yourself a firewall and set the permissions levels. I use Zone Alarm and allow no updates without me saying OK to a request to connect.
Bob
Go into your bio's and diable ALL of the remote turn on option and then if you are NOT using the machine TURN IT OFF. You will save elctricity and cut carbon emmissons. You do know most computors are COAL powered. If you fine thd the computor is coming on by itself, most have a switch on the power supply in the back that can be turned off and then not power in H&LL can turn it on.
Kent
