OT: Need Help to Identify Rims
El Toro
A retired policeman in SC needs help to identify these rims he found. They look to be from a 1934 Ford. Hal
Like Bill... From My 1936 ford. Same wheel, same hub cap. I had saved the wheels and some body stole them.
Kenny
To the best of my knowledge that wheel was used in pass and comm from 1932 thru 1935.
1932 was 18"
33=34 was 17 inch
35 was 16 inch in wire spokes.
36 was steel disk with different bolt pattern. Kinaa looked like a early VW Beetle wheel.
Wheels got moved around during the war due to tire shortage. Hope this helps.
34 Ford my folks had after WW2 was 16 Inch rear and 17 Front. I would assume that during the war the owners used what they could get.
I have a pair that look exactly like those on a utility trailer that Grandpa built from a ford model B axle. The tires on them are 5.25/5.50 x 17". Coker tire has tires that size and also has replacement hub caps for those rims. Good luck, Mike
