White 2-105. If the O/U looses oil and there are no external leaks, I assume the rear seal is leaking in to the trunion then in to the transmission? Is it possible to get so much oil in the trans and rear end that it'd go the other way?
I was cutting hay two weeks ago with it and when I was turning right going up hill, it hesitated in underdrive then caught itself. I didn't even monkey around, I went home, shut it off, checked the oil in the O/U and it was low. I had to add 3 quarts. Next day it was down another quart and that got to be the running theme every day until I got all done cutting and baling.
I started filling silo Friday and was hauling wagons with it. It was right on the add line and I was just hauling a short distance to unload, so I figured I'd wait a day to add since I have to take the side of the hood off to do it. Mid afternoon I tried to start up in 6th underdrive with a full load and when I got it moving, something slipped and shuddered and scared me, so when I got in the yard, I put a quart in it. When I shut it off, it was way over full on the dipstick. Yesterday morning it was still showing way over full. This morning,same thing. It's over full by at least the same distance as it is between add and full on the dipstick. I had added probably two gallons over the two weeks that I was having to add. Now it's making oil instead of loosing it. It doesn't have the smell of gear lube, isn't discolored or thicker than normal. Just looks and smells like good clean hy tran oil.
