I am at the engine rebuilding stage of rescuing the Farmall M on which I grew up. Had the engine put thru a hot tank but it has sat for months while I tended to other things. I ran a light hone thru each cylinder to remove the hot tank residue as well as some surface rust. My (thin wall) replacement sleeves are pretty close to 4.125 plus a few tenths. I ran the bore gage thru each cylinder and found the parent bores to be egg shaped. Specifically, cylinder-to-cylinder direction they are ~ 4.125.
However, in the direction across the engine they are all .002 over size. I assume the sleeves, when installed, will take this same shape. Is this acceptable for a tractor that will see light tillage at most?
