Pencil injector puller dimensions
Celeriac
I need to pull a pencil injector and cannot find my old homemade tool. To fabricate a new too I need of the correct measurement of the distance across the flats of the injector. I've tried but can't get anything in there to measure it. Any help would be appreciated.
Cheers,
Aaron
I use a roll head bar or a large screw driver. pencil nozzles need to be thrown away anyhow, especially if they have been leaking and carbon seals them in the bore. my two cents
If you take the hold down clamp off you might be able to get in there for an approximate measument with a pair of dividers perhaps?
The bugger is between the valve cover and the manifold/turbo. About zero room to work. I may have to see about borrowing a puller.
