pencil injectors for 1650
RGinMN
This is probably a dumb question. I am replacing the pencil injectors in my late model 1650. The shop manual talks about needing a compression seal 0.125 inches thick. The diesel pump shop that does work for me tells me that the "compression seal" is already built into the new injector; its part of the casting for the inlet line. Can someone confirm this or do I need some type of additional washer-type seal? Thanks.
The pencil injector should have the teflon seal already on it. There is also a plastic washer at the top, that should be on it also. If these ars on the new injectors that's all you need. Is your shop manual for the direct injection engine? Maybe it's refering the copper seal for the indirect injector? WB<><.
The injectors have the white teflon seal near the nozzles. It's my understanding that is the "carbon seal", but no other washers.
I recall a copper washer about that thick being used when we replaced injector nozzles on our '69 1650 diesel (direct injection). It goes down into the nozzle bore before you insert the nozzle itself. Your old ones may still be in the head.
Something is not right. To the best of my knowledge, Stanadyne has not done away with the washers at the top of the injector that control insertion depth. There should be a white carbon dam near the bottom of the injector. Then, there is a washer that goes up near the top. Both are plastic. I run the red washers at the top to drop the injector in a little further instead of the black. They say it helps with starting.
Top (washer) on mine is more like a bushing. It's about 3/8 inch tall made of some sort of black hard plastic.Keeps injector from going in too far. (1655 direct injection)
I called O'brien Implement and talked to their parts people. They have a so-called 'kit' with both black and white seals. From their description, the white seal sounds like the carbon seal which mounts down toward the injector nozzle, and the black nylon-type seal is more in the shape of a washer and is 0.125 inch thick. Both seals have a separate part number, so I think this answers the question. There are two seals for the pencil injectors, separate and apart from the injector itself. One is the carbon seal and the other is the compression seal that mounts on the injector shaft immediately under the inlet line. Thanks.
I looked at the picture you sent me from youe vendor. It shows the seals on there. NOW Oliver came out with thinner seals at the top to add in combustion and starting. I will try to scan that for you over the weekend. Do you have the head off? If so get the valve protrusion set right and that will also help starting, more so than that kit. J.
Quote "There are two seals for the pencil injectors, separate and apart from the injector itself. One is the carbon seal and the other is the compression seal that mounts on the injector shaft immediately under the inlet line."
You've got it right, The carbon dam and the washer at the top. I guess I never considered that washer a compression seal. New injectors usally come with both washers/seals. WB<><.
Certainly not part of the casting - maybe they mis-spoke or you mis-undestood. Compression seal is the teflon ring. I've repaced many.
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=1966Roosamasterpencilnozzleclose.jpg" target="_blank">
1966Roosamasterpencilnozzleclose.jpg" border="0" alt="Photobucket
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=1966Roosamasterpencilnozzle.jpg" target="_blank">
1966Roosamasterpencilnozzle.jpg" border="0" alt="Photobucket
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=Roosamasterpencilinjector.jpg" target="_blank">
Roosamasterpencilinjector.jpg" border="0" alt="Photobucket
</a>
