Pequea 710 question
HiPoint OH
Just wondering if anyone has used the 7ft Pequea tedder with a 9ft moco. Did you narrow your windrow - was it satisfactory? Thanks
in case you did not know this, Pequea sells a 9-foot fluffer/tedder - model 910. I use a 710 and works great with my 7-ft mower, but I do not use a 9-ft moco. Good Luck
I have a 9ft (cutting width) CaseIH 3309 and it only lays down a 6 foot wide swath. If your mower is similar, then you shouldn't have a problem.
Even if the swath is 8ft wide, you will probably do ok since the edges usually dry a little faster then the middle anyway.
Josh in WNY
