Percentage pull ?
Depends on if your pulling dead weight or transfer sled. Dead weight is you weight the tractor then you start the pull when the weight on the boat reaches the weight of your tractor. Example if your tractor weighed 4000lbs you start at 4000 on the boat and usually they add 500lbs at a time until you can't pull it anymore. We allow 2 attempts and the pull also. 1948 mm has the explanation of the transfer sled.
the wt of the transfer sled PAN--when pull stops divided by pullers wt. Sled owners can calibrate their sled as follows---------windup wtbox,park sled-pan on scales weigh ------------unwind wtbox 1 ft re-weigh---------------------unwind wtbox 1 ft re-weigh---------------------unwind wtbox 1 ft reweigh------------------------fine tune increments of weight,NOW your SLED is calibrated for PERCENTAGE and DISTANCE.
