Pics of syncro-range problem.
louis110
There was some confusion, methinks, with my last post about our syncro. Our 3020 is in park, on a hill, and the lever says it's in third. I CANNOT MOVE THE LEVER. I can start the tractor, but am afraid to let the clutch out. We had a buddy with an IH come and give it a push this morning, and the lever still wouldn't move. Any suggestions?
Is it still on the hill? I would have pulled it on down to the level with the wheels scooting, then worked the shifter a little while feather ing the clutch some I think you could still just be in a bind,,from the looks of the hill and the shifter it looks like you need to start the engine and hold the brake then try to pull it firmly into the reverse position and then let the clutch out slowly this "normaly" takes the pressure off the park gears..
regardless, 1st thing is to get it on level soil! cant do any repairs where its at! absolutely MUST be moved so mizewell get to it.
(quoted from post at 17:27:18 04/05/09) There was some confusion, methinks, with my last post about our syncro. Our 3020 is in park, on a hill, and the lever says it's in third. I CANNOT MOVE THE LEVER. I can start the tractor, but am afraid to let the clutch out. We had a buddy with an IH come and give it a push this morning, and the lever still wouldn't move. Any suggestions?
Did you push it backwards up the hill? It should come out of park if you pushed it backwards up the hill.
Had a 4020 once that did this. If there was enough slack for the lever to move between the drums then you should be able to pry and wiggle it back into the park position.
Tyler
I think what others are saying, even though the lever is in 3rd. The transmission is still in park. To releave the pressure on the park gear it needs to move up hill. The levers are spring loaded by design. Holding the brake and of course the clutch, move the lever into the gear to move up hill. 1st if you are pointed up hill or Reverse for your case. Holding the lever against the spring and it should pop out when you release the clutch.
Now back to how you describe your problem. It"s stuck in 3rd and the lever will not budge, not even spring resistance. My guess is the linkages are out of sync, no pun intended... There are two linkages from the control down to the side of the transmission under the right battery box. The safe solution is to drag the tractor to level ground to work on it. But another not so safe option, you could park another tractor or heavy truck on the up hill side. Using chains and several load binders or a heavy come-a-long pull the tractor up hill to remove any binding. I suggest this so you can more precisely adjust the pull. Then work each control linkage until they are free again. A service manual would help here to understand the linkages. Basically, one is the range the other is the gears within the range.
Hope this provides some help.
Jason
I have had this happen more than once on my 4020 in the last 30 years. You should be able to get the tractor out of park.
YOU NEED TO BE ABSOLUTELY SURE YOU HAVE THE TRACTOR SECURED, SO IT CANT MOVE IN EITHER DIRECTION WHEN THE PARK IS RELEASED. If you can, pull the tractor uphill by sliding the rear wheels until you are on level ground. Having the tractor on the level will be better, but you must still be sure it can't move, when park is released. I know it seems like overkill on the warning, but anytime heavy machinery is under pressure, and you are in harms way, caution must be used.
After securing, you must get down on the right side, below the operator's platform, behind the battery box, and determine which of the two shift levers is under pressure and move it out of park with a bar or a wrench of some sort. I can't remember which if the two arms is the right one, but you should be able to figure that out.
In the future try to not put the tracror in park on any incline that will cause undue pressure on the park lock. If you do get it locked, and many before you have, hook on and pull slightly to relieve the pressure and the park will release.
Good Luck, Bill Jewison
(reply to post at 09:27:18 04/05/09) [/quote]
It looks to me like the left half of the shift quadrant has moved back to the park position. Is that correct. If thats the case the latch that is supposed to lock the two halves together isnt doing its job. These tractors do have a power assisted park release but the range selector should stay in the first range once the lever is moved into the speed selector side. my guess would be that the speed side is actually still in neutral and that the range went back to park and your shift lever got caught in the middle so to speak. If the tractor starts and the neutral safety switch is operational in the 10 series tractors then the speed side of the quadrant is in neutral. I think what you need to do is unhook the linkage either on the quadrant or the shifter cam for the left side, and roll the quadrant down far enough to get the lever back to the left side put it back in park and hook the linkage back up so that both halves are back in sync. Once you get your lever back you will need someone to give you a little pull up hill just enough to take the tension off while you try to take it out of park. Once you get it off the hill i bet if you take your shift quadrant apart youll find that the latch (part 26 on page 68 of the parts catalog on jdparts.com) is worn out and no longer keeps things positivly locked when under pressure.
FWIW; I think JWJ has a really good idea of what happened. It sounds VERY likely since the left side is still up in the park spot.
Get the pressure off the gears by pulling it backwards a tad. Have the cowl cover off and then try to get it all back lined up in neutral. Or at least get the park out and in a range your gear 3rd. can stay there so you can drive it back to the shop and pull the shifter all apart and rebush it to tighten it all up.
On an unrelated note, that 3020 is a nice looking one. Hope you can get the linkage unstuck. Our 2010 did something sorta like that when I was young (so I don't recall all the details). We ended up getting into the transmission and one of the shift collars was worn and popped out of the linkage. I was maybe 10 when that happened so its all pretty fuzzy.
Jason Z gave good advice.
The bottom shaft is in park and wants to stay that way because of the bind caused by the hill.
Start the tractor and pull your shifter into the low reverse position and GENTLY let out on the clutch. GENTLY because technically the transmnission is locked up by being in two gears at the same time on the bottom shaft (normal park) and one gear on the top. That's three gears all at the same time. Let out Gently!
When the gears start to turn, the bind on the bottom shaft should disappear letting it pop out of park and life SHOULD be good again. Letting the clutch out in first (since it's headed down hill) puts MORE bind on the bottom shaft instead of less. That's not gonna work. Gotta go to reverse.
The tractor is still in park if you can hook something to it to take the torque off of the gears then you can use a big screwdriver and turn the left half of the quadrent down to the lever by doing that it will be out of park . There is a dog in the shifter that lock the 2 halves together that is out of place when the lever is to the right it locks 1 half in position and when the lever is to the right it locks the other half . to correct this the left quadrant has to move down to the lever .You might not even have take any linkage pins out. I just fixed one 2 weaks ago that had the locking dog fall off then you don't know what gear you are going to find cause both halves of the quadrent can move more then 1 range at a time . Trust me I am right on this. M W J Let us Know when you get it going.
That dog is the reason the lever won't move any futher to the right in that slot and even if it did it would not go into reverse because the left quadrant is still in park.
