Pioneer coupler tool
I have one on my desk now we are using for a shop project. safeway #s45-3, 3000 psi max, 4bh.
that is the numbers on the side of the female coupling, I plan to put a set on my skidsteer to replace what case has on there.
Would help if we knew if the coupler was on Air or Hydraulic.
Air system
Push-Button Tru-Flate type coupler work great. Press the button once it releases the pressure between the tool and connector, press it again and it detaches from the tool.
Have not saw a set of pliers for connecting/disconnecting hydraulic couplers. But have use this tool a few times in tight places.
Don't see why a decent metal worker could not fabercate a set of jaws and weld them to a pair of channel locks.
Are you sure the system is depressurized? I have had some problems then but I have figured out how to get around it. Once on my wood splitter d to loosen a line.
Been using the 9500 series for several years. They work good for me.
Lever Actuated Quick Couplers with Dust Covers. (9502-4)
