Pioneer couplings 3/8inch
old-9
Does anyone know what size "O" ring used on 3/8 inch pioneer coupling? My loader needs one bad. thank you, joe
If it's REALLY a 3/8" body coupler (odd in my ag experience, but perhaps not in the CUT world) it should be an "industry standard O-ring number" 116.
The more common 1/2" body couplers us an "industry standard O-ring number" 211.
Not sure if I remember correctly but I think the couplers used on Deere combines were 1/4" and not 3/8" and never heard of an inbetween size. This coupler was used on the hydrolic real lift on series 45 combines and probably more.
Looks like I need to add more info- this is a "Pioneer aftermarket coupler.It has 3/8 inch pipe thread in and out. I added this to my loader so I could R&R without undue work. I have one coupler that leaks bad. I have replumbed so it is not an emergency ,but want to repair it. thanks joe
(quoted from post at 12:17:36 03/26/20) Does anyone know what size "O" ring used on 3/8 inch pioneer coupling? My loader needs one bad. thank you, joe
Was the info I posted below earlier today of any use to you/was it correct?
My little NH compact tractor cane with 3/8 inch connects. I had to put on normal 1=2 inch.
Paul
Thank you Bob, I looked up the #116 o rings and they look to be the right size. I will measure the old one tomorrow and see if I can get local. Will post back, joe
