Pipe thread sealer ofr hydraulics
I need to replace/repair a hydraulic line on my JD MT. The shop manual says to use an appropriate pipe sealer on the coupling threads but it doesn't say what to use. This is my first time replacing a hydraulic line, can anyone tell me what an "appropriate pipe thread sealer" might be?
The most appropriate is none at all.
Some (very little) teflon paste on only the treads involved (sparingly) may be used.
But by all means avoid teflon tape, as shards have been know to find their way through the system causing trouble in valves and such.
I have been using Teflon tape on hydraulic fitting threads since 1960. The problems come about with the tape when you start your wrap and have tape below the first thread. If or when you remove a fitting it is necessary to clean all the shavings of teflon out right then. The paste would be good as well. You still do not want the paste to get over the end of the fitting or it can also cause a spool to stick after it sets up.
If not used correctly either one can cause a problem.
I use "Loctite PST" pipe sealer with teflon,
it is "anerobic" (spelling may not be correct,
but that means it sets up in joints in the
absence of air) it works on 3000 psi fittings
and fitting dissemble easy, and no teflon tape
shreads.
I use Gasoila Soft Set and on natural gas lines too. Do what's been suggested on keeping it off the starting threads. Hal
i believe Loctite or Permatex (are they now the same company?) makes a hydraulic sealer that comes in a liquid form in a tube. I used it when I installed my loader and it has never leaked.
It depends on what type of threads they are. Only NPT threads need a sealer. JIC flared fittings and ORB ports don't use any sealer on the threads. Teflon tape will work fine as long as you wrap it back a couple of threads from the end and don't leave a loose end to get inside the line. You only need about 2 wraps around the fitting. Dave
I've used teflon paste pipe dope in the past. Lately have used anti-seize. My fittings or orb or jic. Don't daub it on. Don't get it around the ends where it can get into the system. Just a light amount on the threads as a thread lube so the fittings will make up tight. The teflon paste may work as a lube and seal the threads incase the mechanical jic seal seeps. I may go back to using the tpfe teflon paste after reading this thread. I have a large 3/4" jic that seems to want to drip and it is T I T tight.
I think with the o rings on orb a little oil helps them. Its hard to keep oil off the threads anyway working around the tractor. So the oring and threads usually have some oil before the anti seize goes on the thread and oring. I don't think the teflon will hurt the oring so I'll probably oil the ring and thread and then use the teflon paste in the future on orb fittings.
Main thing with the antisieze is so they will unscrew easy the next time.
Anyone try a combination of oil, antisize, and teflon paste on threads? I have a fitting to change, guess I'll try it.
