Pitcher pump leather presertive?
I have an old pitcher pump I want to put back to work. I have a new leather valve and cup for it but is there anything I should treat the leather with first? It shouldn't see too much use so I'm wondering if the leather would dry out too much.
Thanks for any info!
My Grand Mother's summer kitchen had a pitcher pump in it. It would set from late fall to the next spring empty without being used until it got warm enough to warrant moving the cooking out to the summer kitchen. She would pour a 1/2 cup of vegetable oil in it when she was done with it in the fall. She claimed it made the leathers last longer and not dry out. She would then prime the pump in the spring with HOT water the first time. She would pour the hot water in and let it set a little bit and then pump water until it cleared up from the well.
Neetsfoot Oil is the best, followed by Distilled Olive Oil, & finally by Vegetable Oil.
I've used an old Pitcher Pump off & on for nearly 60 years and I've used all three depending on what I had on hand at the time. Only replaced the leather ONE time about 35 years ago only because it was flat wore out, but the leather was still soft and supple.
Doc
Whatever you use...be sure to check if it"s ok
foe human health, for instance...what kind of
chemicals, or carcinigans, are in neatsfoot oil ?
Do you plan on using the water for body washing or even drinking? If so do not consider most of the sugjustions as it will make the water not safe for that.
