Remember, correlation does not mean causation. You put oil in the air filter & the tractor did not start. You also sat on the seat & the tractor did not start.
There are any number of things that could cause it not to start ranging from the simple & most likely (flooded spark plugs as Dell sez) to the more complex & unlikely. But, until you narrow it down to spark or fuel, like souNdguy sez, you will be chasing your tail.
It is important for you to tell us if your tractor has a 6 volt or 12 volt electrical system & if the distributor is on the front of the engine or on the side. The troubleshooting is different based upon the configuration of your engine. You said it's a 9N; if so, the distributor is on the front of the engine. Right?
There are three very important tools you always need to have in your N tool box: a 3 inch piece of wire w/ alligator clips on each end, an old spark plug w/ the gap opened to 3/16” and a 7/16 box end wrench. And, you really do need a working ammeter. With these tools, you can quickly narrow down most N problems to spark or fuel.
First, replace the plugs like Dell said. Next, check for fuel. Remove the bolt in the bottom of the carb; as long as the fuel is turned on, you should see gas flowing out of the carb. If it’s a dribble or none at all, you have solved half the problem: it’s fuel related. If gas flows well out of the carb & only stops when you turn it off at the sediment bowl, chances are very good it’s not a fuel problem. So, next, crank the engine & look at the ammeter. What is the ammeter doing? Does it show a constant discharge, no movement at all, or does it dip? Next, get the old plug, ground it to a rust & paint free spot on the head, turn the key on & crank the engine. You have three possibilities: no spark, weak and/or intermittent yellow spark, or a bright blue spark. What is it? Unless it’s a blue/white spark, you have a spark problem. If the ammeter shows a constant discharge, or doesn’t move at all, that also tells you that you have a spark problem. Jump the ignition switch w/ your jumper wire & see what happens. If it runs, you found the problem.
If it does not have gas coming out of the carb at a steady stream w/ the bolt out, you have a fuel problem. First, remove the gas cap. Your vent could be clogged & it vacuum locked. If that doesn’t work, tap the carb bowl w/ a hammer handle in case the float is sticking closed. (don’t whack it w/ the head of the hammer; you can crack the bowl). If you still don’t see gas flowing, the N has three fuel screens; one in the brass elbow, one in the top of the sediment bowl & one on the stem of the sediment bowl in the gas tank. Check the screen in the elbow & the screen in the top of the sediment bowl. (don’t worry about the one in the tank) Both probably need to be cleaned. If you have the fuel knob turned on all the way, it may be trying to feed off of the reserve inlet which is probably clogged. Only open it 2 full turns. Put at least 2 gallons in the tank.
Please be sure to post back & let us know what the fix was. We all learn something if you tell us what worked!
50 Tips
