This is the wiring I took off!This was on the Funk I just got. A previous owner had "converted" it to 12 volt by putting in a 12 volt battery & coil. Is this from an early N?
The generator looks like the one on my '41 9n. It may have been reworked to be a 12v. A 12v battery will still work,but the generator will not work and the cutout will just burn out.This was on the Funk I just got. A previous owner had "converted" it to 12 volt by putting in a 12 volt battery & coil. Is this from an early N?
Likely 2N10000, 9N10000C, 8N10000A. 6 volt 11 1/2 A output, 4 1/2" barrel dia and 5 1/2" length.This was on the Funk I just got. A previous owner had "converted" it to 12 volt by putting in a 12 volt battery & coil. Is this from an early N?
Additionally, the lack of bolt hole in barrel for tension bracket likely rules out the 2N10000 and the absence of Field & Gnd terminals means you can rule out 8N10000A.Likely 2N10000, 9N10000C, 8N10000A. 6 volt 11 1/2 A output, 4 1/2" barrel dia and 5 1/2" length.
I have seen these gens put out 17 volts, but if allowed to output at 17v and substantial current, I feel reasonably sure that it would soon overheat and burn up
WOW Jmor!! That's WAY more info than I expected! From the mount, lack of side terminals, & H/L "switch", it looks to me like the 9N1000C?Likely 2N10000, 9N10000C, 8N10000A. 6 volt 11 1/2 A output, 4 1/2" barrel dia and 5 1/2" length.
I have one myself. Somewhere there is a man rebuilding a tractor that he wants "original" and he is our buyer....or you can make a 6v battery charger out of it.Additionally, the lack of bolt hole in barrel for tension bracket likely rules out the 2N10000 and the absence of Field & Gnd terminals means you can rule out 8N10000A.
If it only has the one terminal post on the rear plate then it is either a 9N-10000-C or 2N10000 unit. Both are virtually the same unit except the 2N has the tensioning bracket anchor bolted to the barrel. These units are the 6V 1-Wire/3-Brush "A" CKT, 11.5 AMP units and the singe terminal is the ARMATURE connection, and rear 3rd Brush Adjustment Screw shown on back panel, and required the 9N-10505-B Round Can Cutout. Used after April 1940 til 1947 for all 9N and 2N Production.This was on the Funk I just got. A previous owner had "converted" it to 12 volt by putting in a 12 volt battery & coil. Is this from an early N?
Not JMOR but I can answer this. The OEM 9N-C and 2n GENs are not hard to find originals and always a better choice than to get a new aftermarket junker made today. Finding one with the tensioner bracket on it intact is the hard part. Many are missing the 2nd piece that bolts to the head. BTW, the 6V 1-Wire/3-Brush 11.5 AMP "A" CKT unit is the only one made today and sold as a replacement for all N's and that ain't right. You'd have to make other changes depending on which model tractor/system you are replacing. Early 9Ns and all 8Ns would require the Round Can Cutout. CAVEAT EMPTORWOW Jmor!! That's WAY more info than I expected! From the mount, lack of side terminals, & H/L "switch", it looks to me like the 9N1000C?
Now the question is - Is it of any value, or are they a dime a dozen? If some rebuilder wants it it's for sale!
It is not often that I would deign to correct Tim because I learned everything I know about these generators from Tim. I this case I think there is a typo, which can happen to anyone. Early 9Ns and all 2Ns require the Round Can Cutout. 8Ns did have regulators. I might add that as Tim has said before, the first few 9Ns did have a regulator, but there are very few of those left.Not JMOR but I can answer this. The OEM 9N-C and 2n GENs are not hard to find originals and always a better choice than to get a new aftermarket junker made today. Finding one with the tensioner bracket on it intact is the hard part. Many are missing the 2nd piece that bolts to the head. BTW, the 6V 1-Wire/3-Brush 11.5 AMP "A" CKT unit is the only one made today and sold as a replacement for all N's and that ain't right. You'd have to make other changes depending on which model tractor/system you are replacing. Early 9Ns and all 8Ns would require the Round Can Cutout. CAVEAT EMPTOR
Tim Daley (MI)
The tensioner brackets were initially a clamp on retrofit, then a factory bracket that bolted to the barrel, then a strut on the rear mounting bracket. There are pictures of the brackets in these threads
https://forums.yesterdaystractors.com/threads/2n-generator-belt-tension.418933/
Generator/Belt Tension
I have an 8N 6V. The generator is mounted with a bolt through two brackets on the generator. No matter how I tighten things, over time the generator moves making the fan belt a bit loose. I recall seeing a picture of an additional bracket of some sort on the list...but have not been able to find...forums.yesterdaystractors.com
Picture of generator belt tensioner?
My original generator belt tensioner is long gone. I saw a proper one a couple of years ago at a fair, but can't quite remember how it worked. Can anybody submit a picture of the tensioning device? Please. I think it was a big bolt that sat in behind the generator and maybe pushed...forums.yesterdaystractors.com
look like this:Wiring 2N with 8N10000A Genny and 8N10505C Regulator
First, thanks to JMOR and Tim and others for the help with wiring and identifying the generator. Pardon me for plagiarizing the artwork from JMOR's pictograms. Thanks to Tim for the education regarding tensioners, which explains both the overheating and dead battery. The tractor is a 2N with...forums.yesterdaystractors.com
Later, they looked like this (part #s 10151 and 10145)
Correction: EARLY 9N and all 8NS used a Voltage Regulator, NOT the cutout. MY BAD.Not JMOR but I can answer this. The OEM 9N-C and 2n GENs are not hard to find originals and always a better choice than to get a new aftermarket junker made today. Finding one with the tensioner bracket on it intact is the hard part. Many are missing the 2nd piece that bolts to the head. BTW, the 6V 1-Wire/3-Brush 11.5 AMP "A" CKT unit is the only one made today and sold as a replacement for all N's and that ain't right. You'd have to make other changes depending on which model tractor/system you are replacing. Early 9Ns and all 8Ns would require the Round Can Cutout. CAVEAT EMPTOR
Tim Daley (MI)
