Plow value$$$ ?
Bruce from Can.
Need to know some idea of the value if a CaseIH 7500 4f semi mount varied width.Looking for a dollars and cents answer, not a opinion about plowing in general. Also anyone who has had experience with the 7500 plow , will it bury corn stalks right behind the combine or will it plug up ?
I guess it would have to be. But not what I had intended to say. Plowing a field after the corn has been harvested without chopping stalks with a flail chopper , or dragging a set of disc-choppers over the stalks.
Don"t know that plow but if it is a high clearance plow than 100 bu corn probly, 200 bushel corn maybe, 300 bu corn probly not. Doubt you"ll get 100 percent buried regardless. My2 cents
$1500 to $2000. Usually if you don't deal with the stalks in the fall you have to deal with them in the spring and it is much easier in fall then spring.
(quoted from post at 10:43:27 11/04/10) $1500 to $2000. Usually if you don't deal with the stalks in the fall you have to deal with them in the spring and it is much easier in fall then spring.
I think I agree on the $1,500 to $2,000, and maybe even higher. The more modern moldboard plows that are big enough for todays big tractors are still somewhat in demand.
Take the coulters off and u ll have no problem ploughing corn stalks. My 720 with the coulters off ploughs them perfectly. Trash boards also will make a big difference one your coverage.
