Anonymous-0
Just wondering what tractor HP vs number of plow bottoms you guys use ESP in the 80 hp range. I have a 82 HP turbo diesel JD 2140 cab tractor 2WD and it pulled a 4-16" plow 3 pt hitch 12" deep just fine, was in 4th gear 2400 RPM. I know soil conditions will come into play, this was in good bottom land, i haven't tried it in clay yet, i would say it would still plow good around 8" deep???
Also while plowing the tractor wanted to go to the right, i had to turn the wheels to the left all the way through the field, it was adjusted level, since then i filled the front tires to add weight, maybe the landing was off???
