pappajack101
now dont lol to hard at this question/statement;;
I am pulling a 1 bottom plow......1 furrow down
the field;;so to keep from driving back to start
how is the next furrow pulled?
I know it am at the start to put tire in furrow.
But still comming back--throw furrowother way?
Plow another furrow going the other way throwing the dirt over where it lies from the first furrow. then you go back and forth on either side. Note you need to start in the center of the plot you are plowing. You will end up with a furrow at each side. or you can start from the outsides and work to the center. You will be driving empty on the ends. For a larger plot divide it up into manageable plots like this.
Throwing a furrow the other way would not work. You need to start what is called a land by making a trip acros the field in a straight line, and then come back the other waw plowing close enough to throw the dirt from a second furrow toward the dirt from the first. The trick is to get the two furrows to overlap enough to be smooth, no gap and not too much overlap.
You"ll get all kinds of ways-but,I start on one side,plow down to end turn around and plow back on the other side of garden.Just remember to keep the right front tire in the last ferrow plowed(plow throws to the right)that way new plowed dirt will go in upside down in last ferrow.Go to Brindleys site and there"s a pic.Clear as mud-right?dude11
Some people start at one side of the field and go all the way around the field in a counter clockwise direction and just keep going round and round until they end up in the center of the field. I leaves one furrow in the center instead of one furrow on each side of the field.
Hope this helps,
Harry
i have fun learning to plow.
went down middle of field,then up bottom side.
no way can one polw with out an over lap,one
place or another.
ideally my harrow smooths out the furrow and
im ready for planting.winter wheat yes.
deer like it
