Pi$$er ain't it...always a dissenter out there somewhere!(quoted from post at 22:59:18 12/20/09) Electronic Ignition replaces the points. EI uses an extremely simple, reliable magnet going past a solid state module which creates the trigger to spark your plugs. No more grease. No more adjusting or filing. No more points. No more worries about worn distributer bushings as your dwell is always exactly right.
Your tractor will start better. Perform better. Have more power and use less fuel. Isn't that amazing. And yet some folks insist that you continue to use points. Because they're good enough and have worked for 60 years.
Best of all though is that girls will like you better if you have EI. They know that your tractor will start better in -20 temperatures and they fall all over them selves for it.
