Not db4600
Purple you have done nothing more than ask advice, but maybe at the wrong place. You’ve done nothing wrong and you are getting chastised.Well, after six months I finally have a roof on my metal truss pole barn. First crew abandoned me after sitting the posts. Numerous calls and texts went unanswered. I found another crew building one near me and I went and asked if they would finish mine. They did after I purchased the rest of the needed
2x6 purlins and metal for the roof.
I finished the side that most of my rain comes from but want to close in the front gable end. I was reading where they say NOT to connect your gable end
framing to the truss. They said it should be connected to the purlins and not the truss. Not sure I understand that but don't want to do it wrong. I was wondering if anyone knows how to properly do this. I have searched the web and can't find any good info.
I plan to enclose the gable end from top to ground and have two sliding doors to help keep prying eyes out. lololol
Any advice is appreciated.
Tom
If it were mine I would tip poles or studs or panels next to those end trusses and use a bolted angle connection. Usually a connection point within 3-4” of the panel point is recommended. I can say 35 years experience in building had some merit, but it don’t mean squat here. I will agree that a 2x6 diagonal brace in the four corners of the eave walls would make me sleep better.
The fact that there are integral tabs for roof purlins and bottom chord braces has some merit that the truss supplier has put a pencil to paper.
