Resting Relics 1
Hey guys,
I've got a Oliver 70 that was given to me by an old friend just before he passed away. It was stuck but overall not in to bad shape. It was all there and since it was stuck I was not sure what else might be wrong inside. I pulled the engine apart to free up. Put in new rings,and bearings, honed out the cylinders which cleaned up pretty well and ground the valves. Did a complete tune up for the distributor ignition ie: points, condensor, plugs, cap, rotor, and coil. Set the timing and She started right up, but runs poorly. When I got looking more closely I found a crack in the intake manifold so I replaced both intake and exhaust manifolds which I got from Steiner. Still it runs no better. I checked compression and all six are around 100 pounds. I took the carb apart. It actually looked pretty good. Put a kit in it. Still no luck. It won't pull under load, idles rough and runs rough when throttled up. I bought a rebuilt carb from this site and that makes no difference. I'm at my witts end. I remember working on the neighbors farm when I was boy. He had two 70's and did next to nothing to them and they purred like a kitten. I've spent a small fortune on this old girl and can't believe I can't make it run nicer. Any Thoughts about what I might be missing or some issues these old 70's might have had that could cause her to run so bad? Any help would be appreciated.
John
John
