Anonymous-0
I'm putting in some fencing for a horse pasture and I've been using a tractor mounted (3 pt hitch) post hole digger. The problem is that I hit rock anywhere from 12 - 24 inches below the surface. I'm trying to go down 36 inches.
The rock itself is not particularly hard as I can put some moderate weight on the auger and grind through. Unfortunately the wear on the auger knives is tremendous and I've only gotten 5 or 6 holes before the knives are ground away.
The auger has a replaceable spiral point, and while this gets quite hot, so far its holding up. The knives however appear to be cast metal and can't take the punishment.
My first question is, what do professionals do when having to auger down into "sandy" rock?
Are there replacement knives that are made of harder material (i.e. hardened steel) that might hold up better?
The auger diameter is 6 inches with one knife on each auger edge (2 knives total).
Suggestions?
John
Suggestions?
John
