Power adjust rim will not adjust
Bill741
I have an 861 Ford with power adjust wheels. Recently attempted to adjust wheel width and discovered right wheel only moves about one turn and then stops. Have tried increasing and decreasing air pressure, cleaned all surfaces of dirt and rust and greased with no change. I have also removed all clamps and used tractor, letting wheel turn free. I'm out of ideas.
Pic is of left wheel. (14.9x28)
This post was edited by Bill741 on 07/08/2022 at 07:09 pm.
It's possible the rim is out of round which would misalign the tracks. Not common. If the rim is outta round you may have to remove it and jack it into shape. Also look for damage to the tracks and the leading edge of the hub edge that knifes its way through the track rails.
Movement has to be blocked someway.
When it stops moving is the leading edge of the disk just starting to enter one of
the rail pieces that are welded to the rim? If so take a close look at the
alignment with the slot. I've had some rims that were a real pain to adjust but
never had one that never came loose, after cycling them through the full width a
few times they moved fine after that.
Does not stop in same place each time. Leading edge not entering slot when it gets stuck. I'll measure rim to see if out of round. I'll also check clearance at each slot when it sticks. BTW the tires are filled with calcium and water.
(quoted from post at 03:06:12 07/09/22) I have an 861 Ford with power adjust wheels. Recently attempted to adjust wheel width and discovered right wheel only moves about one turn and then stops. Have tried increasing and decreasing air pressure, cleaned all surfaces of dirt and rust and greased with no change. I have also removed all clamps and used tractor, letting wheel turn free. I'm out of ideas.
You can jack up the tractor and rotate/adjust the wheel by hand. That may help you find the spot that is causing the wheel to bind.
It looks to me like you may be at the end of your adjustment. One rail has a stop no bolt, built right into it at the end of travel.
If the rim turns out to be fairly round I would just keep trying to get it to move
more by driving it around and hitting the brakes to keep working it back and forth.
The only rim I never was able to get to adjust was one that was on a parts tractor I bought
and someone had taken two rims and spliced them together to make one good rim.
Problem was they got the diameter a little too small and there wasn't enough room
for the disk to move anymore. Can you see a non factory splice or some grinding
marks anywhere on the rim by chance to indicate someone may have spliced your rim?
Took several measurements. 3/16" was largest variance. Still need to check clearances when I jack it up.
Jacked tractor up today. With wheel at widest position there is about 1/8"+- clearance. As I turned wheel toward narrowest position all clearance went away. Appears the tire is not totally seated on rim. The edge of rim is not even with the tire as it is on opposite wheel. Is it possible that is causing the loss of clearance as wheel aproaches narrow position? I'm thinking about having someone remount tire. Thoughts?
Jacked tractor up today. With wheel at widest position there is about 1/8"+- clearance. As I turned wheel toward narrowest position all clearance went away. Appears the tire is not totally seated on rim. The edge of rim is not even with the tire as it is on opposite wheel. Is it possible that is causing the loss of clearance as wheel aproaches narrow position? I'm thinking about having someone remount tire. Thoughts? no splices.
I just recently took a set all apart and got them sand blasted, primed and painted, then put them back together. I had none of the variation in clearance that you describe. I was putting them together without the tires on with the center supported on a 5 gal. bucket. they were snug but they went OK. There is no way that a tire being uneven on the rim could be a problem unless the tire is coming up against something like the fender. It sounds like your center is bent. If you can remove the rim, you could set up a gauge with a pointer attached to something on the ground. Turn the center slowly and see how far the center moves sideways. You could measure sideways movement every few inches of circumferential movement. I'll bet that you will find a part of the circumference is different from the rest.
I'm considering removing the center from the rim and reinserting it on the other side of the rim so it is in the narrowest position. I doubt I'll ever reset the width of the tires again. I know I'll have to cut the stop off one side of the rim, the other stop is bolted on. Any unforeseen problems I might encounter? I assume the dish/center will slide/screw into the rim from the other side with just a little effort.
Finally got wheel width readjusted to 56". Had to cut off the stop on the inner side of rim, remove dish and reinsert it from the outer side of rim. Thanks for all the advice.
