power adjust rims
I have a TO-35 that had same problem. I removed all the bolts that hold the adjuster body on the wheel disc. While removing the bolts from the disc one or two of them twisted off.
This was a 28" tire with fluid in it. Once the adjusters are free you can take them apart and clean up as necessary. I had one that had a broken eccentric pin which I then welded. This was a temporary fix until a better one could be found.
I reassembled everthing in reverse of the way it came apart and then tightened the eccentrics on the wheel.
If you have one that will not break loose. Position it on top and take bolts out, then clamp it in in your vice and heat it with a torch.
It should break loose then,
never use oil or wd-40 on them as the oil will collect dirt. I would only lube with Graphite
