Oh well I guess that went right over some heads.(quoted from post at 13:47:27 02/13/11) Just purchase the pre filter like dirt track runs around their air filter . Soak it in nitro freeze it then pull it out of the freezer /cooler and put it on before you make the pass.
Every Engine is affected by Barometric Pressure . The Thawing of Freezing Nitro adds oxygen to the air supply and gets around oxygenated fuel checks.(quoted from post at 18:00:58 02/13/11) About, well when I was a boy, our M pulled 3-14's in 2 gear in gumbo, after dark when the air cooled she would handle it easly in 3rd gear with fire coming out the muffler. That was something I will alway remeber. The old girl sure injoyed cool and damp air.
Air density %=1.73686 X uncorrected barometer/absolute temperature. Everyone should do this formula to know the amount of air they have to use at each track.(quoted from post at 18:38:44 02/13/11)Every Engine is affected by Barometric Pressure . The Thawing of Freezing Nitro adds oxygen to the air supply and gets around oxygenated fuel checks.(quoted from post at 18:00:58 02/13/11) About, well when I was a boy, our M pulled 3-14's in 2 gear in gumbo, after dark when the air cooled she would handle it easly in 3rd gear with fire coming out the muffler. That was something I will alway remeber. The old girl sure injoyed cool and damp air.
-20F(quoted from post at 21:13:03 02/13/11) are you referring to nitromethane? I was not aware it could be
frozen? sounds interesting-
ethanol when used as a fuel by its volume cools the intake charge as well as lowers the entire engine temperature. A wet NOS system does also . Propane needs heat to keep the mixer from freezing etc.(quoted from post at 15:22:22 02/14/11) Dry ice has a surface temperature of -109 degrees
Fahrenheit, methanol has a freezes at -143 degrees
Fahrenheit. So spraying methanol chilled by dry ice
into intake would cool it enough to make a
difference. If memory serves,every ten degree F.
drop in incoming air temperature is one percent
power potential.
Air density %=1.73686 X uncorrected barometer/absolute temperature. Everyone should do this formula to know the amount of air they have to use at each track.[/quote]39.95 Weather station .temperature is F . Barometer is in inches of mercury most barometers are corrected. So rule of thumb from kinsler fuel injection to uncorrected them you need to know the elevation and reduce reading by 1 inch of mercury for every 1000 feet of elevation. Absolute temperature is actual temp added to a value of 459.67. hope this helps(quoted from post at 10:43:04 02/15/11)
(quoted from post at 15:17:19 02/15/11)Air density %=1.73686 X uncorrected barometer/absolute temperature. Everyone should do this formula to know the amount of air they have to use at each track.(quoted from post at 10:43:04 02/15/11)
How much difference in elevation was the tracks that you pull at vs the garage you tune and dyno at?(quoted from post at 10:17:50 02/16/11) I'd alwayse take a look up at the exhaust a time or two on every run mid track to see how things were burning, not that a visual is verry accurate but it gave me an idea. I never did adjust much on the carb, maybe if it was a cool night I may open the fuel jet a bit but it never mattered, best policy was to just leave things alone.
