As far as a floating neutral generator (many come that way) not being able to run some furnaces one needs to know how that genset is actually configured be it direct, or via a transfer switch, and whether or not the neutral is switched, or the gensets n and g are attached to the utility n and g, or a typical genset cord plugs into a receptacle on side of house or the genset is a seperate derived system and connected
What I’m saying is even if the genset has a floating neutral that doesn’t necessarily mean the furnace is wired to a floating neutral. Too much to explain here.
That being said I’m not surprised if a furnace or oven doesn’t work wired to a floating neutral but not getting in all the weeds explaining why that’s above this question.
There is to be only one n g bond,,,, there’s all sorts of ways to connect a portable genset, the whole issue of bonding and grounding and seperate derived sources and when or not ground rods are required is complex and no need to open thst can of worms here unless someone has a specific question , it can’t be covered here in a paragraph grrrrr
In short some devices may need to be connected to a bonded service to work and thee are ways to cure that even if the genset is floating Nuff said And not going in the weeds on and on and on lol elec threads are long enough already
John T
John T
