power steering leak on 7200
Anonymous-0
I have a 75 model 7200 that is leaking from a small bolt on the top of the steering motor where it meets the steering tube. I have tried o rings and can't stop it . I was wonderinmg if it is something farther down and it is not supposed to have oil there. I have an AT manual and a ford repair manual for 7600 and haven't figured out the problem. Any help would be appreciated, Thanks, TC
The bolt that is leaking is the top bolt on steering motor next to the steering tube to the steering wheel. You cansee it when you tilt the wheel forward. I have tried oil resistant black silicone on the bolt and hope it holds. The bolt is a 5/16 with a 5/16 socket head. Thanks for the reply. Fords are excellent tractors except for the steering leaks. I have 2 5600's and the 7000 and all have steering leaks. Thanks, TC
looking for a motto assy, steering gear , for a 7200 ford with tilt sterring , please contact 219-397-2695 ask for raul sr. or leave a message and a number thank you
