power steering pump JD 630
grwrench
hello, JD buddies,, i have JD 630 power steering pump apart,, leaking oil on the fan belt,, there are no oring seals or gaskets between the pump sections,, what do you use to seal this up against leaking??? THANKS
DITTO, new seals, check shaft for wear, thin coat of shellac Indian Head you can still buy. This will seal up the pump.
