Powr trol plugs
Neven
Any help how to remove these two plugs. They don't budge and I've never used them. Is there something else I'm missing.
<a href="http://smg.photobucket.com/albums/v33/neven1963/?action=view&current=a756cbce.jpg" target="_blank">
a756cbce.jpg" border="0" alt="Photobucket Pictures, Images and Photos"
</a>
You just remove the knurled nut and they should slip out. Is the unit rusty? There is generally so much oil around there that they should be well lunricated.
The knurled ring has to be unscrewed & the plug will pull out. There is a half snap ring in the assembly to keep the plug from pulling out.
The half snap ring is a brittle piece made of pressed soybeans or something. If your towed implement came unhitched and tried to be towed by the hoses, it would break and let the plugs pull out rather than tearing up things. Try not to break them, as they are a little pricy to replace.
It must be just that rusty because I can't turn the knurled end. I've tried some pliers and it's not moving.
I have seen people get carried away tightening those, sometimes using a pipe wrench to correct a drip. I would not be afraid to lean on it with a pipe wrench, jusr don;t get carried away. If it begins to move the worst that can happen is that the pipe fitting adapter behind will turn out, and then you can work on it in your vise.
What model are you dealing with. I have a '53 R and on top of my openings(probably on your right side) there is a lever that I have to trip to go inline with the hoses to release the fittings. I hope this helps.
