Anonymous-0
I have a Troy Bilt pressure washer with a vertical drive Honda motor and AR pump. The unit is near new. It has started with ease and runs well until it was used without proper water pressure. We had a valve connected to the hose that was only partially open. While it was running I noticed the closed valve and opened it. The washer functioned really well for about 10 seconds then it shut down completely. When I tried to start it again, it sounded like it has no compression and wouldn't start. I let it sit for a few hours and tried again, same result. Do these units require back pressure from the pump to run? Could the lack of water have blown the motor, the pump?
