BillinCentralMO
Bought this tractor a year or two ago and use it a couple times a month. All of a sudden it is not running right. It will start but it misses acts like it wants to backfire. If I choke it it will smooth out somewhat and then it will die. Wait a few minutes and it will start again. Was too busy to mess with it this weekend. I just used another tractor. I had changed the plug wires awhile back as the old ones were falling apart.But it ran ok right after I changed it. Thought I'd ask you experts where to start. I have two manuals with the tractor and not with me right now. Think it's a fuel supply issue or something else. I did clean the sediment bowl and took a little junk out of it. Gas tank looks ok as far as I could see from the top. Time to rebuild the carb ? Fuel bowl filled quickly when I started it after cleaning the sediment bowl. Gas is fresh.
