Proofmeter Gurus!!?
DON TX
I have a proofmeter that was working fine and then quit. I took it apart and when the gears get to a certain spot it binds and stops. The plastic vertical gear is starting to strip. I can spin it back and forth til it gets to the spot. What's up? I can't see any reason for the binding without tearing into it more and that means possibly destroying it. Any ideas?DON TX
i cant help you with that problem but i can tell you that i am restoring my ford and its geting an electronic tac with an hour meter you can buy one cheaper then a factory proofmeter and they are more practical it sounds like you are in the market for a new proofmeter so you may want to consider it
Who sells these units you're mentioning. I have the same problem. Mine is a typical Chinese inferior product and stopped working at the 7th hour mark.
yes it is a standard hole size for a tach i just bought 6 of them online the other day they havent got here yet but they are around a hundred dollars or more from a parts store or diesel shop 4k tach are made for diesels but the newer ones called programable can be used with any signal input i think i have 2 or 3 of them that are spoken for yet if your interested let me know
Why in the world someone would spend $65 for a not need item, beats me.
My '49 8N has never needed one.
(quoted from post at 20:36:15 10/18/09) Why in the world someone would spend $65 for a not need item, beats me.
ome people just need more troubles in life, Dunk.
Neither you nor I are worried about the starter cranking speed of our tractors either, are we? (N-board) :cry:
If I'm hooking up an implement, it is near idle. If working, it is up against governor limit. What else do I need to know? You know that is how they were designed to WORK. :roll:
(quoted from post at 21:42:47 10/18/09)
Wonder how we could impliment a MAP sensor, and a laptop monitor, hard screwed to the hood?
(quoted from post at 17:36:15 10/18/09) Why in the world someone would spend $65 for a not need item, beats me.
Why must you spend your time cutting people down. "Not needed" for you maybe. Its their money and their tractor. Quit pickin.
(quoted from post at 23:01:08 10/18/09)
When was you appointed moderator?
What the F is it your business what I post?
If you don't like what I post don't read it!!!!!!
You are getting on my last leg, where I do something about it, and put a stop to it.
Out of over 10,000 posts, and over 3 years, you are the only one that I have a problem with?
Might not be ME!!!
put that much out? i never said a price i just said what they cost at a store the 6 i bought online i got for $8 a piece so i bought all he had if your interested make me an offer im not gonna try to get store price for them but on the other hand i got a nice spot on a shelf in my shop for $8 a piece
Well, that's different. When you mentioned $100.00 you failed to mention your discount. I'll e-mail ya. Thanks.
DON TX
