Anonymous-0
I know there is a lot of cumulative painting experience here so I'm hoping to get some good advice.
I have an 1951 8N with a Wagner loader. It's a working tractor, not a trailer queen, but I recently did extensive paint work on it. Where possible I stripped the old paint off to shiny metal, using wire brushe attachment on drills and sanding disks. Then I primed with either Rustoleum Metal Primer or the Ace equivalent. Then for the red I used Rustoleum Sunrise Red. Most of the parts were brushed - a few I used rattle cans for. I used two coats of finish paint over the primer. The gray I obtained from the Ford New Holland store. It's called "Factory Match Finish Paint" Gray Enamel (M1J-957-SE5DS on the rattle cans). I love the gray. It's darker than some of the too white grays I've seen, and in certain light has a very light olive cast to it. I also like the Sunrise Red. I am happy with the results, though some brush marks are visible in places. I customized a few things, painting the lift cylinder bodies,oil filter, oil lines, starter button, check chains & bucket hook in silver. A purist may cringe a little but I think it adds a little pizazz to the look. I hope to redo the rear wheels to do the rims in the original style cadmium type (silver maybe).
My tractor is housed in an enclosed shed and is only out when it is being used, so fading due to weather or sun exposure is not an issue.
My question is: should I apply some kind of clear coat finish over this to protect it, or maybe a wax? And if I do either of those things will it make it harder or impossible to either touchup or repaint in the future?
Thanks for your advice.
Carl
