Protection for a sitting sickle mower
Saw this pic from a post from 26 cows and was wondering what it is made out of? Screen?? I've got a sickle mower that sits out in the farm yard and worry about the kids and or animals getting hurt on it. I've tried to bungie a cedar post on it but this looks better.
two pieces of plexiglass heated up and bent over and secured by bungi cords. Note the overlap in the middle.
I use a piece of old fire hose split in half. Tie it on with a small rope, because it sticks out to the side = I don't want it colored to match the tractor.
Another thing you may want to do is, if you have a table saw cut a slot in a piece pvc, or black abs pipe, and secure with what ever you have. stan
Its plexiglass. I got a small sheet and cut in half. Then heat it up and bend over. Also heat the edges to smooth them. Plexiglass has sharp edges. Got the ideal at a show a year ago. Show required that the blades get covered. David
If you're just gonna use it at the "farm" then it's more function than fashion.. I would personally use (and have used) plastic drain tile. My grandad and uncle do tiling for a living, and the "short" pieces from the end of a roll they usually toss in a pile for a small repair job or whatnot, so I'd just go get what I needed from the pile.. A 8 foot piece was about 4 bucks, (give or take) last time I got some.. (Yes, I'm the family member who tries to be honest about stuff, even if it's in the "scrap" pile)
It's pretty easy to cut, and don't seem to get brittle sitting in the sun..
Brad
I bought a John Deere mower in the 70's that had a piece of wood (maybe 1 X 2?) with holes drilled all along it that fit over the points on the guards. I think I still have it put up in the shed. Will get some pictures if I can.
