That is exactly what I do. I have the pto unit, a "Dayton" (I think it is Generac relabled and sold through Graingers) which is 25KW and 50KW surge, to use for long term outages,
I mounted it to a TSC three point carry all, and welded on some hooks for holding the industrial cable that hooks it to the house, along with a rack for the pto stub shaft and tarp hooks so it stays clean when stored for the 99.9995% of its life.
I keep a 6500 watt Coleman in the garage next to the panel. Both use the same Anderson power Pole connection plugs into my manual transfer switch.
Here in N. Florida, we'll get a late afternoon storm that knocks power out for three or four hours, 10 or so times a year, and the little gas unit will keep the TV, lights, computers, ceiling fans and such running just fine for a short time. If we we get a major event like a hurricane, the large unit gets hooked up because by the third or fourth day the house starts to get pretty warm when missing its 5 and 3 ton AC units. Been a while since we had such a long period of outage, but we were in Italy for two weeks in '05 and the daughter had to house sit in our powerless house for 11 days. She had places to go and stay, so she just emptied the refridgerator. That's when I started looking for a large pto unit, and I found one 30 miles away, still in plastic wrap. The fellow bought it for hurricane use and relocated to a northern city before he could even hook it up. It weighs as much as a 455 Olds V-8, so it's too heavy for my 855 to lift, though it would spin it at lower power use if needed. I use it on the 4310, and have even run it with the VAC Case, again at lower power output. It's nice to burn in different engines now and then, but I pretty much just use my M&W dyno for that.
The 4310 will run every light in the house, while pumping water, with the washer running, but if you hit the start button on the clothes dryer, it will slowly grind to a halt, so I know the tractor is a little short on power, but that's not a bad thing. I just will need to manage the power a bit and not run everything all at once, or, put the 70D on it and let everything turned on.
Now, my philosophy about too big or too little. It's far more expensive to run too small a unit, overheat it too many times, and have it burn out when you need it most. That's what happens to many little gas units around here. Most sucumb to failure on the electrical side, and not the engine side. Lots of go carts around here running ex-generator engines.
The little bit of extra fuel cost is negligible IMHO, when compared to how much cooler my 25KW unit is when running at only 8 or 10 KW. Also, the larger armature and inertial mass of this 1800 rpm large unit, smoothes out the power pulses when using the 70D on it. Of course, my choice in size was also predicated on the deal that I got, so bigger was much, much better in my case. I could get by on less, but it sure makes for fewer decisions at a critical times like emergencies.
I use a Kill-O-Watt meter at the generator, and another in the kitchen so I can monitor it when I set the throttle, and from the house as well. I bought an oil pressure cut out "Murphy" switch (used on Thermo King units) to protect the 4310 in the event of an oil pressure loss. It's a handy idea even during regular times. It ought to be standard equipment on tractor engines.
The 70D isn't as much of a concern for me, but I have thought that a fella could design a similar cut out system using a small cylinder like they use on tool fixtures, powered by the engine oil pressure pushing against a spring loaded throttle linkage. That might be a project for the winter anyway.
