Acquired this a few months back, got around to using it and seemed like the pump was sucking air towards the end of the stroke(slowing down and not going all the way up). There is a pipe elbow with a plug in it about 3/4 of the way up the ram, with it raised I added a few quarts of oil and it lifts better but pushes a little oil out of the rod seal when body is set down. The dump body is made by Mullins Body and Tank Co of Milwaukee, not sure if they made the ram as well. Not sure if it is a ram with a reservoir welded around it or a double acting cylinder where the rod side is used as the reservoir. Any insight would be appreciated.
