(quoted from post at 16:24:32 07/25/14) No it wouldn't.
Used to pump 750 gals all summer long with a M off the belt pulley.
Allan
(quoted from post at 18:56:38 07/25/14) Back when I was a kid, Dad had a very old DC Case on a PTO pump. I would guess we ran it for well over 8 years, pumping 1200 GPM. Little to no pressure. Just enough to get the water up the hill, then it dumped into an irrigation ditch. The pump was an old Fairbanks, I think. Big enough you could get some nice Blue Gill swimming in the ditch. Pretty sure it never burned more then 3/4 gallon of Propane an hour. Only reason we switched, was he put a pivot in.
The next pump was a WD 45 motor, running a Berkly pump. As long as you were up against pressure, like 120 psi, it would run great and cool. Try open discharge, and it would get hot, and burn valves.
(quoted from post at 17:20:32 07/25/14) Showcrop,
You are correct with this, because the outlet piping pinches down the outlet and reduces the flow.
(quoted from post at 12:02:28 07/26/14) It could be either a cooling problem or it could too much load for your tractor. That can not be determined from the information provided. I did a quick Google search for water pump horsepower and found a lot of good sites with online calculators.
I used one online calculator from Washington State University:
120psi pressure
500 GPM flow rate
75 percent pump efficiency =
46.6 brake horsepower.
That would be about 85 percent of your tractor's maximum power, about the maximum continuous load you would want on a 55HP tractor. That is a pretty good match if everything is at face value.
Now into the details:
Are you actually moving 500GPM at 120psi? If 500GPM is the maximum GPM rating of the pump at almost no pressure, you could actually be moving much less flow at 120psi, requiring much less power.
Is your pump rated for 120 psi or more? If it isn't you might be in a less efficient range for the pump, requiring more HP. The pump curves for your model pump would be very helpful. They should be in the operators manual, or from the manufacturer.
Is your tractor rated at 55 PTOHP at the 1500 RPMs you are running it? If the tractor is rated 55 HP at 2500 rpm, a somewhat lower HP at 2100 RPM standard PTO speed, and it is throttled down to run at 1500 RPM, then it would be overloaded trying to turn an actual 46 HP load at only 1500 RPM.
More detailed info would help.
If you have 40 psi at the sprinklers, the 30 to 40 foot rise is 13 to 18 psi, so your friction losses are between 40 to 60 psi, about half your power requirement. Can you take any low cost steps to reduce your friction losses?
