LachineMI
- Location
- Lachine Michigan
Did this about a dozen times. In neutral, clutch in, PTO engaged, brought the RPMS up quickly to 540 on the PTO, then back down to idle, then back up as quickly as the engine would throttle up, then back down. No clutch slip sounds, or squeals or .... Just acted like they had been mated for life.Like I said before hook the brush cutter to the tractor with the transmission in neutral. Get the cutter up to speed then push the clutch all the way down and try and bring the motor to idle. The cutter driving the clutch disc from the back and the motor hooked to the pressure plate from the front trying to move at different speeds is usually enough to break them apart when the pressure plate is in the released position.
In fact it may break apart just having the cutter hooked to the PTO the clutch down and the starter trying to turn the flywheel.
This may or may not work but it is worth a try because that clutch is more than expensive to replace.
I did not get a chance to talk to the dealership, but should be able to tomorrow.
