PTO tire pump variations
valley77
I searched the archives for my answer but didn't see one. I do know there are pumps for different size PTO shafts and one for the flywheel but what tractors do the different sizes fit. I got a odd box of stuff and there was a pump in the bottom. I've seen a regular one for a standard PTO and this one is smaller. Did a B run a smaller PTO shaft or is the smaller one for an H or L or something odd like that? I'd like to know once and for all so I can tell when I see these pumps.
If I understand it right the B ran a smaller shaft and the G ran a larger shaft, thank goodness for modern standardization.
The L and LA"s required a side flat belt pulley and an adapter that fit inside the pulley. The pumps also had a different crank and had a "guard" on them as well. All of this information is found in PC-442. You will find it quite helpful. Randy
